(Americas Only) 5-9.6 kW | Split phase | AC-coupled retrofit inverter (HV)
DESCARGAR PDF >>
Micro-grid applications
Whole home backup
undefined
undefined
GoodWe’s A-BP series is designed to supplement an existing on-grid PV system and connect with high voltage batteries to seamlessly upgrade to a full storage system. The inverter can boost the PV system without the grid, ensuring the on-grid inverter stays connected if the grid is compromised. With frequency shifting, the A-BP can regulate the output power of the on-grid inverter and change the AC frequency to prevent over charging the battery. With an inbuilt smart meter and plug & play AC connectors, the inverter is easy to install. The A-BP can support whole home backup and is compatible with various brands of on-grid inverters.
Whole home backup
Ultra rapid charge
Automatical frequency shifting
Whole home backup
undefined
undefined
A-BP Series supports micro-grid applications, ensuring the on-grid inverter stays connected in case of grid failure. It is compatible with any brand of on-grid inverter.
All the loads in the house can be connected to the backup side, ensuring power supply for all loads if the grid is compromised.
GW5000A-BP
80~495
Max. Charging Current(A)
50
Max. Discharging Current (A)
50
Output Voltage Range (V)
211 to 264 @240
Protection Degree
NEMA Type 4X
GW6000A-BP
80~495
50
50
211 to 264 @240
Protection Degree
NEMA Type 4X
GW7000A-BP
80~495
50
50
211 to 264 @240
Protection Degree
NEMA Type 4X
GW7600A-BP
80~495
50
50
211 to 264 @240
Protection Degree
NEMA Type 4X
GW8600A-BP
80~495
50
50
211 to 264 @240
Protection Degree
NEMA Type 4X
GW9600A-BP
80~495
50
50
211 to 264 @240
Protection Degree
NEMA Type 4X
