LVSMT Series
12-20 kW | Three phase | 3 MPPTs
DESCARGAR PDF >>
Desplazarse
undefined
Low voltage
Latin
98.8%
undefined
undefined
undefined
Max. efficiency up to 98.8%
Full-load running at 50°C
String level monitoring
130% DC input oversizing
110% AC output overloading
PLC Communication
undefined
Low voltage
Latin
98.8%
undefined
undefined
undefined
200V-950V Wide MPPT Volatge Range
Compatitable with High Power Module
DC input current 15A
DESPRIPCION GENERAL
GW12KLV-MT
Máx. voltaje de entrada (V)
800
2
Máx. eficiencia
12
Tensión nominal de salida (V)
220, 3L / N / PE or 3L / PE
GW15KLV-MT
800
2
Máx. eficiencia
15
GW20KLV-MT
800
2
Máx. eficiencia
20.7
