LVMT Series
30-50 kW | Three phase | 4 MPPTs
DESCARGAR PDF >>
Desplazarse
c04ic-275.svg
Low voltage
Latin
undefined
undefined
Developed as an efficient response to South American market needs for low-voltage inverters, GoodWe’s LVMT series inverter is suitable for medium and large scale commercial rooftops or ground-mounted solar PV systems where maximum versatility and profitability are important. With its compact design and power boost function, GoodWe’s LVMT series can provide extremely high efficiency of 98.8%, thus offering a faster return on investment.
String level monitoring
Up to 180% DC input oversizing
Up to 98.8% max. efficiency
.png
Full-load running at 50ºC
Power line communication
undefined
Low voltage
Latin
undefined
undefined
Four MPPTs Maximize Output
Improve your energy harvest with four MPP trackers to minimize output losses caused by partial shading and other mismatch effects.
High Generation
With 180% DC input oversizing capability, the LVMT allows users to significantly expand the solar array and drive increased power output even under low solar radiation.
180%
DC INPUT OVERSIZING
AC OUTPUT OVERLOADING
DESPRIPCION GENERAL
GW30KLV-MT
Max. Input Voltage (V)
800
33/33/22/22
Number of Strings per MPPT
3/3/2/2
Nominal Output Power (kW)
150~300
GW35KLV-MT
800
33
3/3/3/3
36
150~300
GW50KLV-MT
800
44
4/4/4/4
50
150~300
