(South Africa only) 5-10 kW | Single phase | up to 4 MPPTs | Hybrid inverter (HV)
DESCARGAR PDF >>
UPS-level switching
AC bypass
Strong backup
undefined
undefined
undefined
<10 ms UPS-level Switching
AC bypass switch
AFCI ready & rapid shutdown
Strong backup power supply
Well-designed integrated architecture
4 MPPTs – higher yields
UPS-level switching
AC bypass
Strong backup
undefined
undefined
undefined
Featuring 4 MPPTs, the EHB (5-10 kW) is the perfect solution to feed solar power to large residential properties, offering you more choices and maximizing total solar generation.
GW5000-EHB
80~495
Max. Charging Current(A)
50
Max. Discharging Current (A)
50
Number of MPPTs
3
Number of Strings per MPPT
1
GW6500-EHB
80~495
50
50
Number of MPPTs
4
1
GW8600-EHB
80~495
50
50
Number of MPPTs
4
1
GW0010-EHB
80~495
50
50
Number of MPPTs
4
1
